It is currently Sun Sep 14, 2025 1:10 am
 Post subject: epoxy pore fill
PostPosted: Fri Mar 08, 2024 5:45 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Can I do my epoxy pre fill (walnut, rosewood, hog) over target waterbase sanding sealer or should I fill the raw wood first.
Mike McNerney
 Post subject: Re: epoxy pore fill
PostPosted: Fri Mar 08, 2024 6:13 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
I recommend filling the raw wood first
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Fri Mar 08, 2024 7:32 pm
City: U.P.
Raw wood pore fill with epoxy for me too.
Brian R, Wood Mechanic
N8ZED
PostPosted: Fri Mar 08, 2024 7:38 pm
After which is there any purpose to sanding sealer?
These users thanked the author meddlingfool for the post: bcombs510 (Fri Mar 08, 2024 7:52 pm)
PostPosted: Fri Mar 08, 2024 8:16 pm
Do you mean vinyl sealer? I still do it even though I'm not sure it's necessary.
PostPosted: Fri Mar 08, 2024 8:40 pm
I was talking about the water based sealer he mentioned. Seems superfluous after epoxy…
PostPosted: Fri Mar 08, 2024 10:12 pm
The two professional guitar finishers that I know both use epoxy to pore fill and then shoot finish. Seems to work fine for $35K guitars and others.
PostPosted: Sat Mar 09, 2024 10:08 am
That is how this "non-professional" finisher likes to do it also. I think sanding sealers and vinyl sealers affect the clarity and the adhesion of the top coat in a negative way.
These users thanked the author Clay S. for the post: Hesh (Sat Mar 09, 2024 5:24 pm)
PostPosted: Sat Mar 09, 2024 8:19 pm
I've never tried the vinyl sealer with Mohawk Instrument laquer, just with Deft as I had good success without so still not sure if it would be beneficial or not. It didn't seem to make much of a difference with Deft. On the fence.
PostPosted: Sun Mar 10, 2024 11:04 am
Hi Darrel,
Here is a page from the wood web discussing vinyl sealers that might help you decide what side of the fence to be on, although you really don't have to make a choice - there may be projects were you prefer to use it and some you don't.
https://woodweb.com/knowledge_base/Is_V ... %20surface.
For epoxy pore filled wood on musical instruments I don't use sealers, and for soundboards I self seal with top coat (and try to keep it thin). We picks our poison and takes our chances. bliss
These users thanked the author Clay S. for the post: Hesh (Mon Mar 11, 2024 4:31 am)
